I have an 06 Eiger,and want to replace the drive belt.
This 4wheeler sees alot of mud,and high water.
I am going to replace the stock tires with something more aggresive.
The stock belt seems to slip a little.
Any thoughts on what brand of belt,and tires for that matter?
Randy
Used Dayco on previous quads. No probs. Thelatest has 7000 miles on it and no probs sofar. The OEM was replaced at 9500miles and showed no appreciative wear either.
WOW ! Thats a ton of miles!
Thanks for the belt advice.
What kind of oil do you use?thats a lot of miles
Randy
I would like to say hello this is the first time I have been on here.
As for the belt question, I also have an Eiger (03) I have tracks for it and have had to replace the belt for it a couple of times and found the best belt was Carlyle, at the moment I am running a Hypermax, but I think the Carlyle is better. I found the original belt was also very good, as comparable to the Carlyle.
I hope this helps,
Fisherman1792
