1 - 9 of 9 Posts
Hi all,
New to the forum, and would love some insight to a problem that I have been having:
I bought a 08 650 H1 with 1800 miles on it from a local elderly farmer last Spring. Looks and appears to be in great shape. It was running great until the end of the Summer. My son was riding it when is started to backfire unbelievably and then would bog down, and die if you didn't feather the gas and let it sit or catch up. I'd also get an E in the display.
I took it into a local guy that works on UTV/ATVs and he rebuild the carb thinking it was gummed up. He thought he had it dialed in so I picked I picked it up. I took it down the road at about 30 mph for about 1/2 mile and let off the gas and it backfired and it bogged down and I got an E on my screen.
I took it back to the guy and he played with the carb some more, changed the plug, checked the valve clearance, and then installed a new electronic choke. I added fresh gas and it seemed to be better but still had problems after running at high speed for a bit and then let off, still bogs down and I get the E on the screen
I used it to plow this Winter and didn't have too much of a problem, but never probably went over 15 mph.
Took it out two days ago to go clean ditches, we about 30 mph for about 1/2 mile and as before when I let off the gas it bogged down and came to a stop. I let it idle to try and catch it up but that didn't work. I feathered the gas and it dies. I tried to start it and all I got was an E in the gear display. It also would not start unless I pulled the brake in, even though it was in neutral.
I have read about problems with the gear-select switch or sensor (could this be the problem)
I want to have an idea before I bring it to the dealer as with electrical and computers things can get expensive while they are searching for solutions
Any help or thoughts would be much appreciated!!!
Welcome to the forum. What about the fuel pump if it has one or maybe a stopped up fuel filter or screen. Sounds like it’s starving for fuel.
I looked it up. Said it’s having trouble finding out what gear it’s in. Could be the shifter linkage needs adjusted
Thanks again for all of the help. That was what I was also thinking, but when is comes to engines and such I'm all left thumbs. Wood and nails I'm fine.
Maybe getting too much air(crack intake Manifold or Gasket) that will cause one to have those kind of problems. Maybe simple fix with (gasket maker silacone) over the crack or on the manifold. Check close for cracks or bad gasket.
Hi all,
Hey did u ever figure that out im having the same issue with my 06
Hi all,
it sounds like a fuel delivery issue...possibly running lean. Can you tell if its getting hot during the times it is running? Also, I read somewhere several years ago that, in some applications/situations, you fix the E by disconnecting the battery for a few minutes and then reconnect it.
1 - 9 of 9 Posts
