Hi All, New to the site...I recently was given a 1986 Honda Fourtrax 250 that needed some work...I tried to kick it over with no luck. I checked for spark and there was none, so I replaced spark plug and CDI unit as well as the wire from a resistance test. Also replaced the carb. Found timing was off 180 degrees. Fixed that and set valve clearance. Tried kicking over and it sounds like it wants to start, but doesn't kick over. Any suggestions would be helpful! Not too mechanically inclined to diagnose so any help is a lot of help!
