hi there my bike started acting up on me, when the engine is hot it doesnt idle anymore and it hesitates and sputters on acceleration, it gets to full rpm in neutral but not in gear, it seems like its got no power, i checked compression i ve got 120 psi hot and cold engine, i cleaned the carb and fuel pump, i heated up the cdi from a cold start with a hair blower, still runs good cold with the cdi warm, im all out of options here, its been a really good bike this is the first problem i ve had with it,,, any ideas
Discussion Starter · #2 ·
Anyone
So you re trying to tell me that i have the only suzuki in the world that doesnt run right.... anything would be appreciated right now......
sounds like it is not getting enough fuel.. you say the carb is clean, but are the jets blocked or restricted?? if your pilot jet or fuel screw is dirty, that will make it act like your describing.. you say the compression is good hot, so your valve lash is probably ok.. think fuel
sounds like the same style bike I worked on... Look for a fuel pump. if so, it is vacuum actuated. follow your fuel line, if it ever goes uphill, higher than the carburetor, it has a fuel pump. open that bad boy and clean the gunk out of it so the diaphragms work freely.
