1 1YW-46101-00-00 RR AXL GR CASE ASSYASSY 1
2 1YW-46151-00-00 HOUSING, DR SHAFT 1
3 90116-10428-00 BOLT, STUD 4
4 2H7-46102-00-00 BEARING ASSY 1
5 93101-52116-00 OIL SEAL 1
6 93317-55542-00 BEARING, CYL.#17 UR 1
93317-85569-00 BEARING UR 1
7 1YW-46121-00-00 GEAR, DRIVE PINION 1
8 1J7-17537-Y0-30 SHIM, THRUST (0.30T) UR 1
1J7-17537-Y0-40 SHIM, THRUST (0.40T) UR 1
1J7-17537-Y0-50 SHIM, THRUST (0.50T) UR 1
9 93306-30542-00 BEARING 1
10 90387-255H9-00 COLLAR 1
11 29U-46125-00-00 RETAINER, BEARING 1
12 93210-59531-00 O-RING 1
13 93101-38098-00 OIL SEAL 1
14 1YW-46110-00-00 RING GEAR COMP 1
15 24W-46118-00-12 WASHER, THRUST (1.2T) UR 1
24W-46118-00-14 WASHER, THRUST (1.4T) UR 1
24W-46118-00-16 WASHER, THRUST (1.6T) UR 1
24W-46118-00-18 WASHER, THRUST (1.8T) UR 1
24W-46118-00-20 WASHER, THRUST (2.0T) UR 1
16 90340-14046-00 PLUG, STRAIGHT SCREW 2
17 214-11198-01-00 GASKET 2
18 2N4-15371-00-00 BREATHER 1
19 1YW-46152-00-00 HOUSING, BEARING 1
20 93102-65277-00 OIL SEAL 1
21 93316-01301-00 BEARING 1
22 93211-54698-00 O-RING 1
23 24W-46117-00-25 SHIM, RING GEAR (0.25T) UR 1
24W-46117-00-30 SHIM, RING GEAR (0.30T) UR 1
24W-46117-00-40 SHIM, RING GEAR (0.40T) UR 1
24W-46117-00-50 SHIM, RING GEAR (0.50T) UR 1
24 97013-08025-00 BOLT 6
25 92901-08600-00 WASHER, PLATE 6
26 95811-10045-00 BOLT, FLANGE 2
27 1FK-46156-00-00 STOPPER, RING GEAR 1
28 1FK-46157-00-15 SHIM, STOPPER (T=0.15) UR 1
1FK-46157-00-20 SHIM, STOPPER (T=0.20) UR 1
1FK-46157-00-30 SHIM, STOPPER (T=0.30) UR 1
1FK-46157-00-40 SHIM, STOPPER (T=0.40) UR 1
1FK-46157-00-50 SHIM, STOPPER UR 1
29 2HR-46123-00-00 COUPLING, GEAR 1
30 1YW-46172-00-00 SHAFT, DRIVE 1
31 93410-22039-00 CIRCLIP 1
32 90501-16780-00 SPRING, COMPRESSION 1
33 1YW-46180-00-00 CROSS JOINT COMP. 1
34 93399-99938-00 BEARING 2
35 93440-23165-00 CIRCLIP 2
36 93210-85706-00 O-RING 1
37 95701-10500-00 NUT, FLANGE 4
38 341-23469-00-00 CAP, BOLT 1
39 90445-07745-00 HOSE 1
40 90467-07029-00 CLIP 1
41 4H7-46181-10-00 LABEL, OIL CAUTION 1
