I am working on my buddy's suzuki quadrunner, and after replacing the ignition coil, cleaning out the carburetor, and basically patching almost every peice of plastic on the bike, I found that the lower end of the engine was FULL of gasoline, and the remaining oil had mixed with it. When I opened up the oil fill port near the rear axle gas/oil mix POURED out. I have since changed the oil and filter, and it runs pretty good now, my question is, what caused that? and how do I prevent this in the future? *note I have a carb rebuild kit coming via snail mail from ebay. is that all its gonna need to prevent this in the future?
I have heard rumors of possible vacuum/vent tubes tied together from the factory. is that the issue? thanks!
:dunno:
Discussion Starter · #2 ·
well the carb kit worked, but also found out that this @#$% bike has a vacuum powered fuel pump. It was full of old varnish and gum. after cleaning that out, It started and ran beautifully, but I am still concerned with the fuel leaking into the lower end again does ANYONE out there have any suggestions PLEASE?
well it seems to be doing okay, made it through deer season and the abuse that goes with that, just hoping it doesent happen again...
Normally I would be thinking of a leaking float needle valve, or the fuel level being to high, due to the float tab being bent, or a leaking float.. On my 88 250 there is an overflow tube with a hose under the carb. It should be wet there if things are off... That's all I can think of right now..
it seems okay now, Over a month and all good...
