I have a 92 350L 2-stroke. I'm trying to find out what the float setting should be on the carb. Also, I'm getting about 110 pounds of compression. Is this ok?
350l....
Compression needs to be min 100psi best if 120psi for the 350L. Did you test the compression when the engine was hot?
Compression tests are done on a hot engine. This way all the parts expand with heat and get better compression....:thumbsup:
Also, run the test with an open throttle.....
-You can do a wet test which is where you add a table spoon or so of oil to the cylinder and check the compression.. this tells you how well the rings are sealing. If the compression jumps way up, then you have worn rings
Your compression is better than expected....:thumbsup:
