I just got new in the package set of rear brake pads and when I put them on I cannot get the caliper back on even though the piston is fully retracted. I am sure these are the exact ones as the part #s match. When I use just one of the new pads in combination with one of the old worn down pads caliper goes right on.
Any thoughts?
Push the pistons out a little and clean the part you can get to thoroughly. Then press them
back in and see if they retract further. If that fails, you could try grinding down the new pad
faces a bit.
