i just replaced the carburetor and its starts just fine but if you accelerate then stop it will shut off any idea what it is.
That's not much to go on. What kind of carb ? OEM ? Chinese ?
I have the same quad. I replaced my carb with a Chinese model. Stock is super expensive if you can find
one. I didn't change the jetting but I probably will. It's just a tiny bit lean right now so I use a touch of
choke to ride it. I would have used the jets from the OEM carb but they are seriously fooked.
The Chinese carburetors aren't necessarily set up for your vehicle. You're probably going to have
to play around with jetting. First try to determine if it's rich or lean. Also make sure your valve clearances are set
and you don't have any air leaks.
