I am working on a 50cc suzuki 2 stroke that ran when parked a couple years ago. The key was lost so I went ahead and ordered a new ignition for it and a new carb since it had set with gas in it so long aswell as a spark plug. I only get spark to the plug with the ignition off and loose it shortly after, I tried another new ignition with the same problem and also made sure it wasn't just hooked backwards. I completely unhooked the ignition and it still starts and the ignition wires will shock you. Could this be a internal short in the stator or coil? What am I missing?
