Hey All,
I have been getting the flashing battery sysmbol on my gauge panel for sometime now but it seems to disappear every time i turn on the lights. I figured it was because of an Overvoltage condition brought on by my installing a new battery. However i recently replaced the speed pickup and i noticed on checking the output voltage to the sensor i was only reading 10.4 volts. I'm beginning to think i may have an undervoltage problem.
Any tips, tricks, test points where i can verify the stator output?
I would appreciate all help.
:dunno:
Check all wire connections by the headlight switch.
Check Battery With engine off and it should be 12 to 13 volts and running, reved up, should be 13.5 to 14.8 +- volts. this would tell you if the charging system is working correctly.
