Hello to all, this is my first post.
I just bought a 2005 Suzuki Eiger and notice after I've had it a week that the right front hub has quite a bit of top to bottom looseness in it. I took the hub off the spindle and the bearings don't appear to be the culprit. The tie rod is fine also. I ordered bearings and they are due in on 9/9. I don't feel like the bearing replacement will fix it.
Any thoughts? thanks
thanks
Discussion Starter · #2 ·
Correction to the previous post:
I did in fact find a bad outer bearing the was letting the bearing housing have up and down movement in the assembly. Will be installing new bearings tomorrow and it should be fine. Tacomaj
