It looks like a Diesel blowing black smoke. Idles rough and dies. has miss at high speed. Runs the same warm or cold
I have:
Checked timing, it is perfect
Checked compression 90 lbs
Removed air filter intake tube
Leak down test. No leaks at intake with carb removed, or at exhaust. Engine held pressure.
Adjusted valves
Replaced spark Plug
Replaced carb, adjusted screw to 1 1/2 turns out
Tried a different coil
Sprayed around the intake boot with brake clean, No leaks found
I tried holding a piece of paper at the exhaust and it does not suck into the pipe, in fact tore the paper.
Any ideas are greatly appreciated. I am out of them
I have:
Adjusted valves
Replaced spark Plug
