hello to all of you!
I don't know why but I think the "selling ads" forum is broken...I can't post there so I am doing it here...I am new on this site...
I have this for sale (only $3500):
a 2005 custom rhino 660 4x4. I purchased this vehicle to use on vacation.we took it on vacation twice and very seldom used it any other time. it has been garage kept. we have added rear yamaha seats and a custom roll cage. it also has new itp wheels and 26'' itp tires. the factory tires and wheels are also included.it is like new,no scuffs.
Seats are removable.
Approximately 60 hrs of use.
Email me for any questions at: [email protected]
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
ENGINE 4-Stroke Single, Liquid/Oil Cooled w/ Fan, 5-Valve SOHC
DISPLACEMENT 660 cc
BORE X STROKE 100 mm x 84 mm
COMPRESSION RATIO 9.1:1
CARBURETION Mikuni 42 mm BSR
IGNITION DC – CDI
STARTER Electric
TRANSMISSION Yamaha Ultramatic® V-Belt with all-wheel engine braking / High, Low, Neut., Rev.
FINAL DRIVE Shaft
SUSPENSION Front: Independent Double Wishbone, 7.3 in. w/ 5-way Preload Adjustment
Rear: Independent Double Wishbone, 7.3 in. w/ 5-way Preload Adjustment
BRAKES Front: Dual Hydraulic Disc, Twin Piston
Rear: Hydraulic Disc, Self adjust parking system, Shaft Mounted
TIRES Front: 25 x 8-12 NHS
Rear: 25 x 10-12 NHS
LENGTH 112.2 in.
WIDTH 54.1 in.
HEIGHT 73.6 in.
WHEELBASE 75.3 in.
DRY WEIGHT 1,049 lbs.
GROUND CLEARANCE 12.1 in.
FUEL CAPACITY 8.5 gal.
LOAD CAPACITY Bed Capacity: 400 lbs.
TOWING CAPACITY 1,212 lbs.
