If it has a vacuum fuel pump it might be letting fuel down the vacuum hose.
You should redo the original carb.. they aren't hard.The knock-offwill probably be needing tuning when you get anyway. You might as well work on the original which is probably better made and set up for that bike. You'll learn more that way too..
