Hello guys,
I have a 2007 800x2 that starts when I bypass the solenoid but clicks when I go through it.
1. I changed the solenoid and it does the same thing.
2.Battery is at 12.4 and at the starter it is 11.5. I used the same battery to try with the bypass method:confused:
3. Could I of gotten a faulty solenoid from the dealer as well?
4. I have checked all the grounds at the solenoid plug and at the ignition switch and they are good. I really dont want to take this to the dealer but i am scratching my head on this one.
if its clicking i dont think its you solenoid, check and make sure all power connection's are tight
Starter...
I believe there are circuit breakers mounted in the wire between the starter solenoid and the regulator near the battery.:thumbsup:
