i have 2 atvs and both are stalling after i get them started and running for a short moment..i believe its bad gas because both are doing it...is it as esay as just draining the gas..i also smelled gas in the drain tube from filter..
Hi there Jerryl if you think it is just bad gas drain all gas from the tank and carb remove the carb bowl and see if there is dirt grim etc in it if so i would recommend you remove the carb and give it a good cleaning
