This bike is brand new......left over I bought 3 weeks ago.....
Scenario
after riding for several hours and returning to base bike just shut down, discovered a blown 10 amp fuse in the fuse block at the ignition spot.....replaced fuse, bike started and home I went. This happened just after flying through a puddle of about 2 inches deep. I had been in much worse through out the day.
Next time out while approaching a hill through a 4 foot ditch with a 12 foot hill to climb on other side the bike did it again, luckly it happened going into the ditch and not while I was climbing out the other side, bike quit. I immediately replaced same fuse and bike started again and back to base I go......Following morning I was looking at the fuse and it did not look burnt. So I put an ohm meter on it to check and it was good......I then put it back in bike and bike runs.......
I do have a brake light switch stuck on, waiting for new one to arrive, I do have aux lights, however they are on own fused circut independant of ignition, wired straight to battery.
Any thoughts from you all would be appreciated.....Moike
Scenario
