My 570 sportsman ep will turn over run ruff for 15sec then back fire and die. I have checked fuel pressure and that is 58psi I've drained the fuel tank and added new high test changed the spark plug and the battery still no change. Cracked open the case checked the crank shaft keyway it's there. The crazy thing is it's not showing a code can anyone help? The dealer here is crazy expensive$$$$$.
