Hi! Just purchased a brand new 2021 argo xr 500. Day one worked perfectly. Day 2 drove it around our driveway and parked it back in the garage worked perfectly. Day 3 tried to start... it makes a clicking sound you can feel in the seat and wont even attempt to turn over and is throwing a code po560(lights, winch etc work fine). Any thoughts? It is literally brand new I am so upset!!! Thanks all 馃檪馃檪
First thing is to check battery connections. Also the ground from the battery to the frame or engine. If any are loose that's probably the problem. Next check battery voltage. Both static and when you hit the starter button. If the voltage drops to something like 8-9 volts when the start button is pushed, then your battery is toast. To test the starter motor itself, jump the 2 primary leads at the start relay. If the engine cranks it could be your start relay is bad.
