Got a 01 kodiak. The rod bearing failed. It took out the cylinder and the piston. I bought a 04 cylinder advertised it was off a 400 but its off a 450. It has a bore of 85.00 in it now. So if I get a 85.50 mm piston for a 450 will it work? Are the pin diameters the same? Is the pin location the same on the 450 piston compared to the 400 piston.
Thank you in advance for input.
