· Registered
I'm replacing the u joints on the rear driveshaft and have removed the roll pin from the yoke at the transmission.
I've tried to slide the shaft all the way to the differential but can't slide it back far enough to clear the splines on the trans. output shaft.
Do I have to remove the mounting bolts from the rear diff. also ?
:confused:
