I have watched all the videos, but they never show the 2000 explorer. The axle has a very large hex shape portion near the center where the swing arm connects. So what do i do to tighten the drive chain? I have loosened the bolts and they show putting a 1/4" bolt through a hole into another hole in the sprocket. Mine does not have such a hole to insert a bolt.
I should maybe buy a manualfor this machine. Can somebody give some advice ?
Thanks ahead of time.
Discussion Starter #2
I got it. I got a manual and it said I had to loosen the two bottom caliper bolts in addition to the two bolts by the hitch. Worked like a charm. Without loosening the caliper bolts, the axle would not move. Manuals are good!
