I have a Kawasaki KLF-400 atv (I think 1999 model), the air duct part that goes from the air filter to the carburetor doesn't quite reach both ends.
I'm thinking connect it securely at the carburetor, and use a rubber pipe union (the kind used to connect pvc drain pipes in home plumbing) at the air filter housing side.
Has anyone run into this sort of thing before?
A long option is to disassemble ... Remove back fender as the manual suggests, and remove the air filter compartment and re install, maybe it has shifted.
Any ideas are appreciated. Btw, the atv had been running for quite some time this way, I'm guessing getting lots of dust into the engine, thankfully engine still seems ok!
