Gotta love Facebook Marketplace, and the crackheads that you can buy things from on there...
Tire Wheel Vehicle Automotive tire Green
Naturally, I'm like "Hook up the trailer, let's go get this pile of eBay parts!" and hauled *** to this dude's house with 3 crisp Benjamins to wave under his nose. Showed up about 20 minutes early to find him and his buddy hastily reassembling the pile of plastics into a semi-presentable quad, using some real sweet bulk bin galvanized hex bolts from Tractor Supply Racing Co.
Looked it over and handed him the three bills in exchange for a transferrable registration from 11 years ago, and a STACK of handwritten bills of sale from the last 11 years, since apparently no one has gotten it functional (for long). Average ownership period ranges from 6 months to 2 years. Fingers crossed, lads!
Wheel Tire Vehicle Automotive tire Motor vehicle
Got it home, and hit it with a healthy dose of bike wash and the pressure washer, more bike wash, a lot of scrubbing, and more pressure washing to get years worth of crud off of it. The entire left side of the crankcase was covered in an eighth inch of caked oil mud, as though there had been a catastrophic loss of oil at some point in the past, because it was nowhere near the drain or fill holes. Totally opposite side. Managed to find the VIN hiding in there and ran it for giggles.
Product Azure Rectangle Font Screenshot
PO mentioned that he "had it running at the beginning of the season, but it was 'rough' " and that he had cleaned the carb, but it didn't help much. And now it just plain wouldn't fire at all. Kind of threw his hands up and shrugged. So, after cleaning it up enough to turn wrenches without looking like a Texas oilman, I took off the plastics and started poking around. Found a few fishy spots in the harness where previous attempts at repairs had been shoddily made and hidden with black tape. Sorted those out, drained and filled with fresh oil and a filter, and hooked up a battery. Turned the key, got a green light, hit the starter switch and got a little grunt and squeak out of it, then nada. No light, no nothing. Pulled out the DeOxIt D5 and started pulling apart all the connectors and giving them the business. put everything back together again, turned the key, got green light, and starter cranked! Then nothing again. Started fiddling with the wiring and connections while watching the green light, and saw a flicker when I bumped the 25A fuse holder. Gave it a squeeze, and sure enough, the light came on. Thing was full of powdered remains of spade terminals, so I installed a NOS replacement model from RADIO SHACK that had been swimming around in my toolbox for nigh a decade. Sure of my fix, I tried the starter again, and NOTHING again. More fiddling revealed that the OTHER fuse holder (15A) was the same. Homebrewed another fuse holder from spade connectors and shrink tubing, hooked it all up and everything was good.
Now that I could crank it, I poured a couple cups of gas in the tank and pulled the plug to check for spark. Good blue spark, once I cleaned up the theretofore fouled plug and gapped it. Screwed it back in, with a healthy dose of ether, and gave it a crank. Not even a wheeze or a sputter. Off with the carb!
White Motor vehicle Automotive tire Automotive lighting Rectangle
Motor vehicle Automotive tire Bicycle part Automotive wheel system Engineering
So, I think our old friend PO has a drastically different definition of "carb cleaning" than I do. I'm thinking maybe he wiped down the OUTSIDE of the thing, and was shocked that it had little to no result. That white stuff is a combination of powdered aluminum oxide and near-varnish fuel. Has the consistency of slight dried mayonnaise or white library paste, but no pleasant wintergreen aroma to match. A quick perusal of the Amazon bargain bin turned up a carb (BST31SS) and non-vacuum petcock for $25, with a caveat that the carb required minor modifications to fit. Four days and a lot of sandblasting and surface prep on the plastics while I waited, the carb arrived today and I drilled out the ferrules for the choke and throttle cables to accept slip-fit cables instead of thread-ins. Other than that, the only difference was a lack of one vacuum port for the petcock, which I had anticipated and purchased a regular old one with no vac diaphragm in it. Safety first, amirite?
Now with definite spark, and reliable fuel delivery, I started cranking and fiddling with the idle and air screws, managed to get it to fire up - almost literally~ There was a LOT of smoke coming from near the exhaust port on the head, thought I had loose header studs for a minute, then realized it was just more of the old oil mud I had missed while cleaning, burning off between the fins on the head and the exhaust heat shield.
First fire up - lots of smoke
While I was changing the oil, I took the opportunity to pull off the access covers and adjust the clutch and valve lash, so I was feeling OK about running it a little more. Got the idle and mixture set a bit better and decided to test out the transmission and shifting a little.
Testing reverse
Realized I left the parking brake set, so it stalled out. Oops. Another thing I did while waiting for Brown Suit Santa to bring my carb was to remove the diff lockout pin from the shifting mechanism and I wanted to see if it worked. Here's the quad, up on the lift, minus the LF wheel (due to a seized cylinder I've since replaced) with range set to HIGH, and Differential Lock engaged. Worked like a charm. Had to holler at the dog who was camped out below the rear tire ;) Dog under the tire. Again. I think she has a death wish. Or perhaps aspirations of being a jackstand in the pro-leagues.
Testing Diff Lock in High Range
Put the wheel cylinder in, (Dorman w38750 for a 1991 Geo Metro/Suzuki Swift was a precise fit and only $10) to replace this crusty POS:
Automotive tire Rim Motor vehicle Engineering Automotive wheel system
put the wheel and hub back together, put seat back on and fired it up. Made sure it would start again after turning it off.
Long Live The King
All the repairs appear to have been successful all around! I took it out for a quick rip up the street and back, needs a little bigger main jet (it came with a 145 installed, which I swapped out for the 120 OEM spec, but it feels boggy at WOT, so I'm going to experiment a little after I get the airbox back together, but 145 seems like a big jump.
I'll try to post an update once I have the plastics all refinished and installed next week. Pretty sure it's going to be yellow, no camo or green bullshit for me thanks ;) Hope you didn't hate my post.
