Hi everyone,I need help, 2003 400 auto ATV stator failed,going back together the starter was binding,it is the middle gear clearance went away somehow,when tightening the case you can reach im through the starter hole and turn the gear as you tighten it down it binds that gear,top gear no problem,I am testing this with the shift rod out and these starter gears have no washers on either side,Its almost as if it needs a thicker gasket but I doubt that is it.I have seen on the net others describe the exact same issue and never did find an answer.I hope someone here can help.pic will show the gear that is an issue. Thanks
