I recently bought a 2001 TRX250 recon. The atv pulls to the left when traveling on hard surfaces. Doesn't seem to pull much off road. I checked the tire pressure. Is there a way to check the "front end alignment"? Any other ideas???
Have you checked steering shaft and trying checking ur ball joints too on of them might be stuck or somthing or could be a alighment is due
I did notice the outer tie rod end on the right side was bad and I replaced it. It still pulls to the left slightly.
