1 - 20 of 33 Posts
· Premium Member
Engine turns over but does not start
No Fuel
Dirt in fuel line or fuel filter
Fuel will not pass through on-off valve (petcock)
Fuel tank vent plugged
Carburetor starter circuit
Engine flooded
Low compression
No spark
Add fuel as required
Clean or replace valve as necessary
Repair vent system
Clean or replace as needed
Turn off fuel and drain crankcase
A) Inspect carburator venting system for blockage
B) Inspect carburator needle and seat
C) Inpect head gasket
D) Inspect piston and cylinder, repair as required
Check for proper spark plug connection
Engine does not turn over
Dead Battery
Starter motor does not turn
Engine stuck or froze
Change or replace battery
Repair or replace starter motor
Repair engine as required
Engine runs but will not idle
Plugged carburetor pilot system
Carburetor improperly adjusted
Low compression
Crankcase leak
Clean or replace pilot jet<
Adjust carburetor per specifications
Adjust choke per specifications
Repair or replace crankcase as required
Engine runs but will not rev up
Broken throttle cable
Obstructed air intake
Incorrect carburetor jetting
Incorrect ignition timing
Restricted exhaust system
Replace throttle cable
Clean or repair air intake, replace air filter
Jet as per jetting chart for carburetor
Check and adjust ignition timing
Repair, clean or replace exhaust system
Engine has low power
Cylinder, piston and ring wear or damaged
PVT not working properly
Restricted or blocked exhaust
Perform compression check
Clean, repair or replace as needed
Piston scoring
Lack of lubrication
Fill oil tank and bleed oil pump
Check oil pump for proper operation or restricted vent line
Restricted oil delivery
Oil pump drive gear failure
Melted Piston top
Engine overheating
Lean air fuel ration
Air leak in crankcase
Incorrect spark plug
Low coolent level in radiator (liquid cooled)
Restricted cooling fins (air cooled)
Clean carburetor and jets
Repair as needed
Adjust timing per specification
Install correct spark plug
Broken piston skirt
Piston fatigue from scoring
Excessive piston to cylinder clearance
Repair or replace cylinder and piston
Excessive smoke and carbon build up
Oil pump not adjusted properly
Oil pump cable not allowing pump to return to idle position
Synchronize pump to carburetor
Lubricate or replace cable
Engine coolent found in counter balance assembly
Water pump gasket
Water pump seals
Replace water pump gasket
Replace water pump seals
Blown engine
Skirt broken off piston, hole in crankcase
Bearings on counter balance shaft failed
Both result in engine not running, full compression. No crankcase pressure, which is needed for 2 stroke engine
Replace crankcase and other related parts
· Registered
Ho there. I'm having trouble with a dune buggy I just bought, with a 150cc Honda GY6 clone engine. It pretty much falls under the category of "starts, but won't rev up". It turns over and starts pretty easily, but if you hit the accelerator, the engine instantly dies. If I let it run for a few minutes then I can sort of slowly ease onto the accelerator until it revs up a little, but not fast enough for it to actually go anywhere.
Its brand new and only ran trouble free for about six minutes after I got it, so I doubt there's anything worn out. I've worked on tons of lawn mowers and cars before, but these CV carburetors are kind of a mystery to me. If you could let me know what you guys think is most likely I'd appreciate it.
· Registered
2009 Yamaha Rhino 700 - battery went dead and I charged it. Now the digital display only shows a big flashing E. No other symptoms. Machine seems to be running fine. What does this indicate and what do I need to do to fix it?
· Registered
ts brand new and only ran trouble free for about six minutes after I got it, so I doubt there's anything worn out. I've worked on tons of lawn mowers and cars before, but these CV carburetors are kind of a mystery to me. If you could let me know what you guys think is most likely I'd appreciate it.Could you plz help me with a problem? i have a 07 ltr 450, fuel injected and it has a high idol. could you help with wat tht could be. Email me
· Registered
It pretty much falls under the category of "starts, but won't rev up". It turns over and starts pretty easily, but if you hit the accelerator, the engine instantly dies. If I let it run for a few minutes then I can sort of slowly ease onto the accelerator until it revs up a little, but not fast enough for it to actually go anywhere.Its brand new and only ran trouble free for about six minutes after I got it, so I doubt there's anything worn out.
· Registered
I know this is incredibly old, but a common issue in small engines. It's generally a jetting or complete carb rebuild repair. Sometimes, rarely, the float is bad (not enough fuel in carb bowl to feed the monster).
No / Weak spark? Often overlooked is ground. Spark requires a ground to the block... often you can connect a secondary, heat-shielded, heavier ground cable to the crankcase or exhaust manifold and create/improve spark on even a no-issue motor. I found it funny, a billion years ago, to find out ACCEL and similar just use purer metals in their wires to create UBER performance.
1 - 20 of 33 Posts
