Hello,
My grandfather has been having issues with his 2004 Suzuki 450 ATV. He says when you press the start button while it's in Neutral the ATV turns and sometimes sputters like it's going to run and then nothing happens. Occasionally it will actually turn all the way over and it will run perfectly fine until he lets it sit and idle then it will shut off and no longer run again. He has had a full carburetor rebuilt, his spark plug is new, new gas, Coil is new, Additionally when the Carburetor was being built the Shitty Mechanic (Charged him $300 for the carburetor problem never changed...) told him he also checked Valves and Compression and his final answer was "it's just wore out." This ATV has 1000 miles on it.... it's not worn out.. Any suggestions to help diagnose the issue would be greatly appreciated.
