I am looking at the parts blow up on Yamahas web site and I cant find anything.:dunno:
I have an 08 grizz 700 and to start it in gear you have to have the brakes on.
Item Part # Description Notes Req
1 3HN-85540-20-00 C.D.I. UNIT ASSY 1
2 98507-06020-00 SCREW, PAN HEAD 2
3 92907-06100-00 WASHER, SPRING 2
4 92907-06600-00 WASHER, PLATE 2
5 3GB-82540-00-00 REVERSE SWITCH 2
6 90430-10171-00 GASKET 2
7 3GD-82310-10-00 IGNITION COIL ASSY 1
8 90109-06723-00 BOLT 1
9 97007-06020-00 BOLT 1
10 92907-06100-00 WASHER, SPRING 1
11 1UY-82370-20-00 PLUG CAP ASSY 1
12 BTG-GM14A-Z4-A0 GS GM14AZ-4A YAMAHA 1
13 1YW-82115-00-00 WIRE, PLUS LEAD (1UY-82115-00-0 1
14 24W-82129-00-00 COVER, BATTERY 1
15 5Y1-82122-00-00 SEAT, BATTERY 1
16 371-82121-00-00 PAD, BATTERY 3
17 4GB-81960-00-00 RECTIFIER & REGULATOR ASSY 1
18 97007-06016-00 BOLT 2
19 92907-06100-00 WASHER, SPRING 2
20 92907-06600-00 WASHER, PLATE 2
21 4GB-82510-00-00 MAIN SWITCH ASSY 1
22 3HN-82579-00-00 CAP, KEY 1
23 29U-83585-10-00 LABEL 1
24 3AY-81940-00-00 STARTER RELAY ASSY 1
25 95307-06700-00 NUT 2
26 92907-06100-00 WASHER, SPRING 2
27 2HT-83530-00-00 PILOT LIGHT ASSY 1
28 4G1-84744-00-00 BULB (12V-3.4W T-10) 3
29 90445-082F3-00 HOSE 1
30 59V-82150-00-00 FUSE HOLDER ASSY 1
31 705-82151-00-00 FUSE (30A) 2
32 3HN-82541-00-00 WIRE, LEAD 1
33 3HP-82590-10-00 WIRE HARNESS ASSY UR 1
34 1YW-82507-00-00 WIRE, LEAD 1
35 1UY-81950-91-00 RELAY ASSY 1
36 29U-81950-93-00 STARTER CIRCUIT RELAY 1
37 29U-81950-93-00 STARTER CIRCUIT RELAY 1
38 59V-82541-00-00 WIRE, LEAD 1
39 437-83936-01-00 BAND, SWITCH CORD 4
40 437-83936-11-00 BAND, SWITCH CORD 3
41 90464-14117-00 CLAMP 1
42 90465-13169-00 CALMP 1
