recently bought a used 1996 big bear 350 to tool around on.However it will only idle(with the choke pulled out part way).If I try to give it any throttle at all it dies. Wont start at all with the choke in. any help would be appreciated.
Same Issue
Sorry I can't help much but my 2007 Grzzly is similar. It needs to be choked and idles horribly without half choke. Once warm it is fine but getting up & running is a chore. I have some sea foam running thru the gas tank...have u tried any?
No I havent ,but couldnt hurt. Although the carb was just rebuilt. With the intake tube off,it acts like some of the exhaust is coming back through the carb. It sprays a little gas back onto the frame.It will only idle for about a minute or so before it dies.maybe a possible timing issue.
