This is just to help anyone who is having running issues with their carburated quad.
When we talk about Cleaning the carb, here's what we're talking about.
Carb removed from vehicle.
Top cap and bowl removed
Slide and needle removed. Diaphragm inspected if present
Float and float valve removed
ALL jets removed.
O Rings for the float value assembly removed if present.
ALL PASSAGES in the carb body thoroughly cleaned and checked for flow
ALL jets cleaned and checked for flow or replaced.
Float height checked and adjusted
Needle in carb slide cleaned, checked and adjusted.
If you just open the bowl and spray carb cleaner around, you're not cleaning your carburetor.
Hope this helps
ALL jets removed.
Hope this helps
