Hello everyone, I am new here just signed up.
I have a chinese atv with a 110cc engine, I just replced the gear set in the tranny cause fourth gear lost some teeth, it is a 4 speed. So it seems the throttle response is not good in the mid to upper rpm range, also once it gets to about mid range rpm it kinda surges, like a lawn mower with governor problems, it goes and the cuts out, goes and then cuts out. Giving it a surging or intermittent sound. also it backfires alot, don't know if this is due to my tin can muffler or not.
So I just bought a new Mikuni 26mm carb for it cause they said it would improve the acceleration and speed etc. Also purchased the 26mm intake manifold and ported my head intake to 23mm. I made a custom air filter for it, it is basically an electronics project box approx 4.5" x 2.6" with a uni foam filter cut to fit, the box is mounted in the front of the atv. From there I have 2x 1.5" flexible
tubing the routes to a Tee on the carb intake. I have tried no air filter and restricting the air going in to see if I had to much filter area, but still the same problem. O, and also if the bike is in neutral and I open the throttle up all the way it will rev up pretty high then start doing what I described earlier, it also seems that it spits a little out of the carb intake when it sputters. There is no fuel adjustment screw on this carb, but I know you can adjust the mixture by moving the clip on the long needle that is inserted in the top of the carb, I just don't know if it needs to be adjusted or which way to adjust.
right now I am running 17t front and 25t rear sprocket.
Any help will be greatly appreciated.
I have one of these in fact two i bought and the freaken exhaust fell off it. i cant get it back on. i think it is weird how it bows down below the frame. has anyone changed this part and moved above the frame
try having carb cleaned. Mine did that after it warmed up. It was a jet plugged. guys tell me buy avaition fuel for it. It will run better and wont clog carb
