I took it apart for a cleaning/dip. It's only a few days ago, and the two jets seem to be interchangeable. So now I have the question, are they correct in this pic? One has a large hole, and the other a small hole. Which one is which, and what are the correct nomenclature for these ports? I've seen the carb diagram, but nowhere have I seen a "legend" that gives names to the diagram parts.
jets
The jet on the lower side of you picture is the main high speed jet which will have the larger hole# than the low speed jet closer to the top of your picture. The low speed has to be smaller because the engine requires way less fuel than it will than it will with the engine running at high rpms. It looks like you have the two mixed up. The higher the number on the jet the more fuel it will flow. The smaller number on the jet the less fuel it will flow. Hope this helps thanks for the exellent picture. Good luck :cool:
I swapped them, and now she runs like a raped ape! Awesome, thank you 300Arcticcat!
