Yeah i tried to snorkel before out the side of the airbox and tubed it to the rear, coudnt get it to seal to the airbox well enuff to prevent water from getting in. So any ideas?
specs: 1 1/2" lift in front, 28" Outlaws rear/27" mudlights front, high comp piston
The easiest way I know of, and the way I did it is to remove the aluminum plate by the reverse lever and cutting a hole in the plastic where it meets up with the top of the intake tube. I'm not sure if I'm explaining this well enough, but I will try and get some pics for reference. I am currently, however, looking into an alternative mounting location through the front fender. Although this snorkel has worked flawlessly for me, it doesn't look very "professional" to me.
