I am having a problem with the wiring on my 2000 polaris magnum. I am not able to get speedometer to work, front headlight or taillight. I have replaced the spedo and checked the bulb in the lights. any suggestions. Also I replaced one 20 amp circuit breaker.
If the speedo lights up but doesnt register the speed, the Speedo problem is most likely your hall effect sensor that is located on your front right hub. I've run into similar problems with the lights and the issue was where the wires from the switch run past the steering post were cut inside the black plastic coating. This was cause from years of steering back and forth and bending the wires. ~Phil
