I just bought this sunl 110 used knowing it wouldn't start. I even tried starting fluid and it won't start. I have 2 more of these and have switched alot of parts doing trial and error. I have spark so I think I narrowed it down to not getting gas into the cylinder. The carb I have on it is off of one of my other running atvs so I know that it is good. I pulled the spark plug out and it is dry. Any ideas?
do you have compression in the cylinder?
if you have spark starting fluid in the carb should fire the engine,did the engine try to start when you did this?
110 atv no start.
remove spark plug and valve covers. turn engine over are the valve operating? check valve timing could be off. pour small amount of gas into plug hole and replace plug. should start for a short time. i'm not a beleiver in starting fluid for a gas engine. it's made for starting deisels in cold weather. post again and tell us what you found out. :dunno:
Premium Member
If the cab is good, the carb is getting fuel and the plug is dry then your pretty much guaranteed your valves are not functioning properly.
