Sounds like a vacuum leak doesn't it? She idles ok. When you rev the throttle she falls on her face. But if you rev throttle while placing hand over intake tube, she revs fine. I sprayed around the carb & tubing with carb cleaner, to see if the idle dies out (identifying a vacuum leak) and found nothing.
I recently rebuilt the carb. I've had carb issues since owning it. Is it time to just buy a new carb?
Is there anything else I can try first?
