Just came back from the swamp and I drown her pretty good. All is running good now except the gear, she won't let me shift her easely. The engine reves a bit higher than normal. What did I off set?????
I gave her CPR ie cleaned up the air filter compartment and plugs, there was no water in the oil and she started no problem. I did burn the belt a bit and she may need a new one.matthewmarcus said:Just came back from the swamp and I drown her pretty good. All is running good now except the gear, she won't let me shift her easely. The engine reves a bit higher than normal. What did I off set?????
