I have a 02 Vinson 500 I just replaced the top end an new gaskets. I did a cupple oil changes to get all the water out of the bottom end it was all going good till I put it all back tighter it had coolant in the Radiator the whole time I was doing the oil changes and when I brought it out for a test drive it started leaking coolant back into the oil so It started to smoke the oil got really milky I pulled the water pump out and there’s a bunch of coolant behind that I’m just not really sure what to do to fix it or what I have to do from here plz help
If you have coolant behind the water pump it means the water pump seal has failed.
Replace the seal and you should be good to go. Inspect the water pump shaft too. If it
has any deep grooves in it, that will also need replacing.
