i have a 2002 polaris magnum 325 and im having these problems with it
when i turn the key the lights don't turn on but i can start it if i pull the recoil start it starts fine and the lights come on but they are are running off the alternator only
the kill switch is in the run position
and i just changed the battery and i checked the voltage from the wire going to the battery it was at 12.6V
and the wire coming out of the selenoid was at 0.9V
should i replace the selenoid?
anything could help thanks
