Hi we have an 02 Yamaha Blaster 200cc any sugestions on how to remove axle? Have clymer manual and followed what it says but not working. Removed left side wheel hub and axle nuts-2. then slide wheel hub back on as manual said to use a hammer and pipe to pound axle thru to the right side-- tried but only slide right about an inch.
Thanks for your help
yes axle is completly free, nothing attached other than brake hub and rotor which is to right side. Even had entire axle out and carefully placed in vice to try and hammer out like manual says. do not see any visible retainer clips, or does manual show any BUT are there? Thanks
I'm pretty sure there isn't any clips or anything else in there to hold it. I have the factory service manual and I just looked at it and it doesn't show anything else holding it, either.
