I need help please. I have a 2001 Big Bear 400, 3 three years ago I had issues and was working on carb and broke a jet. I bought a jet kit put it in and then moved. I had taken and rebuilt the front end and just last month put rear end back in it. So it hasent ran in three years until now. Wouldnt run so I took the all jets (I think) out and cleaned carb. Now it will run while giving it gas, idle when in neutral, but will idle real high and if I adjust it down it will die. I need help in fixing this. Please
brian
do you only have one adjustment? or is there more. sometimes there is an Idle adjustment screw and a Idle Air screw. Do you have a Clymer book?
