i bought a 97 300 fourtrax the other day that needed a cdi box. i put one in it and it fired right up. well next i noticed that none of my lights wouldnt work including headlights and neutral reverse and oil temp light. i checked the battery and it didnt have a drop of charge. when i went to drive the atv it would die when you got it past a idle. I put a battery in it and it would drive but not like it should seemed very week and still none of my lights would work. can anyone help?
Charge up your battery and start the atv. While running check your voltage with a multimeter.Kill the atv and check voltage. Should be about .5-1volt less then while running.
I think you have multiple problems. Start with the above and go from there...
Hi,
Hi,
I think you need to contact any ATV mechanic who must be able to solve this things in a well manner for that you can search on web also.
you will get easily contact details.
Thank you.
