Why hello there folks,
Just wondering if you guys have any suggestions to whats going on. I just purchased a 2003 Rincon 650 and I noticed a few things it does. I noticed that whenever I put it in Drive or reverse it grinds a little. Is this grinding normal? If I shift it in quickly with the foot break peddle on I noticed it doesn't do it or just a little. Another thing I noticed is that when I put it in reverse it likes to stall out. I'm thinking maybe its idling too low. If its an idling problem can someone point out how I can adjust it?
Thanks in advance,
Grinding would indicate idle speed too high, Clutch engaging or out of adjustment.
Stalling: dirty carb , idle mix out.
Is there any PDFs out there that would explain to me on how to adjust the idle speed and checking what you just suggested?
thanks,
My Rincon was leaking gas. I took the carburetor off cleaned it and reinstalled it. When test driving, the thumbing the gas lever in full, I was not getting but about 1/4 power. I took it to a mechanic and he thinks it may be the throttle sensor. Does the throttle sensor have that much impact? It was running fine before I took it apart except the leaking of gas through the overflow. Anyone have any thoughts?
