1 - 10 of 10 Posts
· Registered
Hi All. Am working on an older King Quad, can't find any numbers on it, and it won't fire. I cleaned tank, put in fresh gas, check for spark all good. I even sprayed some gas in the cylinder and did not even get a pop! Any and all help is appreciated. Thanks.
· Premium Member
The optimal compression should be anywhere from 100 to 125 psi.Simple troubleshoot on a low compression engine
Put one tsp. of oil in the cylinder through the spark plug hole.
Run compression test
Higher compression = ring problem
No compression change = valve problem
1 - 10 of 10 Posts
