That's a bit quieter alright.. Good work.
And about the clutch. It is not pretty. It’s got it’s original belt. The primary sheave is filled with black sludge instead of grease. And the wet clutch underneath looks pretty bad. It’s got some little chips all around it and there are slight grooves in the clutch housing. I’m assuming I’m gonna need to replace the housing and it’s expensive so I’m just going to ride it once I get my tires in and we’ll see what happens. If it rides bad I’ll go ahead and spend the money. I have $3,200 in this quad with all the cosmetics and tires so I’m hoping it’s gonna last me many more yearsOh good stuff Brock. You posted while I was typing.
Yeah I couldn't think of any real reason the clutch would knock, but all the crank bits looked so good. Did the new crank come with a rod? Sounds a whole bunch better. EnjoyAnd about the clutch. It is not pretty. It’s got it’s original belt. The primary sheave is filled with black sludge instead of grease. And the wet clutch underneath looks pretty bad. It’s got some little chips all around it and there are slight grooves in the clutch housing. I’m assuming I’m gonna need to replace the housing and it’s expensive so I’m just going to ride it once I get my tires in and we’ll see what happens. If it rides bad I’ll go ahead and spend the money. I have $3,200 in this quad with all the cosmetics and tires so I’m hoping it’s gonna last me many more years
Yeah this crank design is all pressed together and the rod doesn’t bolt on it’s just a ring. You’d need some pretty precise tools to press a new one on and measure it right. Since I have you does anyone know anything about Yamaha coming out with a grizzly 1000?Yeah I couldn't think of any real reason the clutch would knock, but all the crank bits looked so good. Did the new crank come with a rod? Sounds a whole bunch better. Enjoy
