So I have my 2000 Yamaha Kodiak 400 she runs wonderful but the second I turn on the headlights or my BOSS speakers mounted on it runs like absolute garbage will bog out if I give it slightest much of throttle. Didn’t use to do this
Have you checked your charging system output lately ? Maybe it's not charging and it's running
everything off the battery.
If you're saying that you run without the battery I'd suspect your stator is starting to fail. You should probably have a battery in the system. It helps smooth out the voltage from stator and rectifier.
