i have a 2002 polaris trailblazer 250 purchased used,wont start tried spark sparks white blue,the carberator was flodding not no more,took off carb and sprayed starting fluid in the intake still wont start please help,
i would try a carb rebuild kit and fresh gas, see where that gets ya. how does the air filter look?
gummed up carb...
You have to take the carb. off and clean it carefully=other wise you will spray all the loose dirt particles into the jets. The carb. float bowl was probably stuck because of sitting.
