ok here is what is crewing me up i need to know if the t on the flywheel lines up with the mark as sson as the piston is at tdc is so than what do i need to do to get mind to line up because as of right now mine is way off
on the 400 bayou (KLF) you have to look through a 3/4 inch hole and line the mark up with the slot. Then you have to adjust the valves. line the mark up with flat (horizontal) with the motor.
If all else fails google " how to time a 220 bayou"(with year) something should come up
